cabin filter
Hey acmech,you have any idea where the cabin filter is on a 2000 accord?The manual says let Honda replace it,I don't see where it should be that hard to do If I can find it.:D
It's located behind the glove box. I would buy a chiltons manual for directions (lengthy directions).
agreed with xmechanic, empty glove box, with the box open, find a way to pull or push the sides inward ( upper fwd soft part of glove box) it will hang upside down and let you see the cabin filter container. some have a slide some have a clip cover to open. pull out filter and replace same. i got my filter from wallmart, napa, autozone, wix, even found some good ones in the salvage yard.... just lucky.
Thanks so much guys,will try that this weekend,regards,Bobby
Aloha Doug,I got the filter out with no problems,found a new one at walmart with your suggestion,thanks again buddy.
I have the same problem with this filter... is not so easy to replace. I find here how to do this..i print this page and like this is more easy..
http://filterlocation.com/honda-acco...lter-location/ Thanks! |
When I changed mine I put a dryer sheet in there as well, works as a prefilter and makes the car smell nice.
Originally Posted by nycredneck
(Post 22814)
