Check Engine Light went on
My check engine light went on my 2000 Honda Accord 4 cyl EX ULEV. I then checked the Manual. It said to make sure the gas cap is tight and drive it for 3 trips. Which I did. Please note I flushed my transmission fluid and had my CPU replaced too b/c of a non starting car earlier this year. Autozone ran a check with their machine and the print out came out with one of these problems, please tell me what I should do:
(Please note because it is not an official Honda machine it could be listed under the wrong manufacturer: Honda: Open or shut circuit condition Poor electrical connection failed TCC system Automatic transmission fault Poor connection at transmission Internal transmission problem Infiniti: Bloced passage in transmission Faulty TCM Kia: Failed damper clutch solenoid Transaxle fault Chrysler: Low fluid level Poor fluid quality Defective torque converter cluter Internal transmission failure transaxle control system fault failure of transaxle control modyle Mazda: Open or short circuit condition failed TCC solenoid valve Acura: Low transmission fluid level Poor electrical connection failed TCC solenoid Automatic transmission fault Nissan: check for poor connection failed solenoid TCM fault Sabaru: TPS misadjusted or faulty MIL light up request BMW: Torque converter clutch circuit open Mitsubishi: Failed TCC Transmission control system - mil request Volkswagon: Failed torque converter clutch solenoid Transmission control system fault Isuzu: No communication with TCM failed TCM General Motors: TCM requested mil illumination The TCM has detected an emission related fault Eagle: Transaxle control system fault ECM received a signal that the transaxle control module has a fault shorted or opend circuit within transaxle failure of transaxle control module |
00 accord had trans recall due to many failures. reset eng ck light and see if it returns, if so have autozone recheck for cause.
