ENGINE CHECK LIGHT IS BACK P0420
Hello, I have a Honda Accord LX 4 cyl. 1999 and I changed the o2 sensor by the manifold (before the catalytic converter) because the code reader from Autozone says "catalytic system below treshold bank 1 " something like that.
So I was told to change the sensor by the manifold. well, the check engine light is back. yes, I erased the code and disconnected the battery. Any idea or similar problem??? Thanks Bounty |
RE: ENGINE CHECK LIGHT IS BACK P0420
Aloha BOUNTY welcome to the forum. Have read many sensor problem like yours, I have been advised that if you put in anything other than a factory honda o2 sensor, that at times the light will return.This was even when it was found out that Honda uses the same type of sensor.
| All times are GMT -5. The time now is 09:13 AM. |
