Engine Oil Type in a different country
Hello,
I have a US 2017 Accord which uses 0W-20 oil. I currently drive the same car in the Middle east. Should I change the oil type? According to the user manual of Accords in the Middle east, the oil is 5W-30. Also, Total lubricants "LubConsult" tool recommends 5W-30 for the Middle East and 0W-20 for the US. Does Honda use different engines in different regions for the same car? If not, then does the weather difference warrant the oil type difference? |
Use what you have been using.
(Post 43872)
Originally Posted by Marduk
(Post 43894)
Wouldn't the hotter climate cause the oil to go thinner? why would Honda recommend a heavier oil for the middle east if the engine is the same globally?
(Post 43895)
You car operates at a specified temperature through a thermostat and radiator. If everything is working as designed you should be good. Even in the hottest parts of the planet an engine needs to warm up.
IFF Honda uses the same engine for each car globally (Which am not sure of), then the oil should change with region according to the car user manual. |
(Post 43904)
The issue is not cooling or lack there of. It is about oil viscosity. If the temperature goes higher than normal, oil viscosity decreases below the designed levels, which reduces the lubrication performance below the initial design.
| All times are GMT -5. The time now is 05:52 AM. |
