-   -   flushing coolant (https://hondaforum.com/forum/honda-accord-forum-11/flushing-coolant-3807/)
bucwheat May 6, 2009 02:48 PM
flushing coolant
I have a 2000 4cyl. Accord and want to flush and replace hoses,do you have to bleed the air from the system afterward? also want to do a tune up what plugs do you guys recommend?:D
acmech52 May 7, 2009 02:45 AM
yes on the bleed of the coolant system. I use platinum, ngk or bosh, got 80k + miles on both type.
bucwheat May 7, 2009 03:24 PM
Is there a bleeder valve somewhere at the top of the motor?
acmech52 May 8, 2009 03:47 AM
it is located on the thermostate case. Go to hondaautomotiveparts.com and dial in your car, go to water pump sensor and you will see the picture and part and #12 called the breathing bolt. Funny name for a water bleed
bucwheat May 8, 2009 11:51 AM
Thanks so much sir. Big help!
bucwheat May 28, 2009 11:28 AM
Easy find ,thanks acmech52,was going to change the belts also but after buying them I took a look at the originals and the looked new so I threw the replacements in the trunk for safe keeping.
