-   -   Front Wheel Bearings Replacement - 90 Accord LX (https://hondaforum.com/forum/honda-accord-forum-11/front-wheel-bearings-replacement-90-accord-lx-806/)
SOKal Nov 15, 2006 12:21 AM
I couldn't find it in the Chiltons but do I need to replace the hub bearing AND the spindal? Some one said so a while back but I figured I check with you all first. The symptoms are a constant hum that goes at the same rate as the wheel spins. It gets progressively louder the faster I go. The CV joints are relatively new but the wheel bearings, well, you know -- 140K old.
pro1955 Nov 23, 2006 01:27 AM
RE: Front Wheel Bearings Replacement - 90 Accord LX
You can replace the bearing and hub without replacing the spindle assy.
