Help with 2000 Accord EX Front Hub Removal
I need to replace the bearings on the front drivers side of my 2000 Honda Accord EX. I have been able to find "Accord 98-2002" videos and walkthroughs but the 2000 seems to be a different setup. I understand it's easier to just get the hub assembly instead of trying to remove the bearings, which is what I did with the rear when it needed to be replaced. The rear came off pretty simply after some elbow grease, but I'm having difficulty removing the front assembly. The wheel has been removed, caliper is off, rotor is off, spindle nut has been removed, but the assembly doesn't want to budge. We aren't able to see any bolts on the back side even after taking the dust cover off but it's possible we may have missed something, otherwise it's just REALLY on there. I was just hoping someone could confirm whether or not there's anything else we need to do to remove the assembly before we get too rough with it. Any help would be appreciated!
deezbs
09-07-2012 09:18 AM
Suze
10-17-2007 03:24 PM
