HFP Rims
I've got a 2008 Honda Accord LX sedan, and I've been wanting to put 18" HFP seven spoke rims on my car but they said it doesn't fit. I called them and they told me that it has something to do with the hub clearance? Is there any way I could make them fit? Any help would be great! Thanks
Spacers may work but then you wouldn't know how much clearence you will have and if it's enough,I myself wouldn't use spacers they can be dangerous if not tighten down properly,by a set of wheels that fit properly and spend less money.
Thanks
if the hub is larger you can use hub centric rings. like with most aftermerket wheels hub centric rings are needed to keep the weels centered to prevent vibrations.
I'm not sure if it's larger or smaller....I don't know if I should go ahead and purchase them and if they don't fit, try to return them? I like those paticular rims cause it's Honda and it doesn't look too "aftermarket"
there are a ton of good aftermarket wheels that look similar at half the price. i would go that route.
