How am i going to fix this?
Reach around behind the bumper and bang it out from the back side. If the dent is in plastic it should just pop right out, but if its in metal then the metal is most likely stressed and after pulling the dent out will require some simple body work to make it flush, bonds will work. Also after you remove the dent you will probably notice the paint is cracked and damaged, so to get it perfect again sanding is needed, then apply paint, sand again, then apply a clear coat then a wax.
Jschoend
Apr 25, 2019 01:50 PM
jennie31
Jan 29, 2013 06:38 PM
