leaky valve cover gasket. need help
i have a 93 honda accord and the valve cover is leaking out the front and leaking and burning on the exaust i was woundering if it was simple to change i know you have to do the sparkplug seals too. all i was concerned with is the timing cover, a step by step deal would help thanks
RE: leaky valve cover gasket. need help
Very simple to perform remove everything connected to valvecover and loosen vc bolts. Refer to service manual but its not hard. Make sure you get the correct sparkplug seals i think they come round and oval.
Aloha bettysteach: Welcome to the forum. If you go to autozone.com,sign up for free, and enter your car info. go to repairs and to engine, it should tell you how to change the valve cover gasket. there also may be diagrams.
| All times are GMT -5. The time now is 09:00 AM. |
