NEED HELP PLEASE 1995 accord bad vibration on driver side
Rack and pinion boot busted. Not leaking fluid.. it's either the rack and pinion or c.v.axel.. vibrates at 30 MPh.. then worsens as I give it gas... any ideas?
welcome to the forum. Are the tires balanced, are the brake rotors no warped, then check the axel.
I'll check that today. I'll get back to you. Thanks friend
A tire that has separated can cause vibration also.
Got a 2000 accord same issue at 60+ it's your control arms. I found a good site for a full front control arm kit if you need
