Newbie with a 91 Accord no start problem
Hello All,
I am new to this site and have a 91 Accord that does not start all the time. It has been towed a few times, the coil in the dist replaced and now the whole distribiter, still no start intermittanly. Anyone might have a clue, or something common to Honda's? relay? etc? Thanks in advance, Kim |
Will it start after sitting a while and when the engine gets warm it doesn't want to run? If so, pull your spark plug boots from the spark plugs and see if you have a lot of oil in the spark plug galleys. If you do, replace the valve cover gasket and the 4 spark plug "tube" gaskets as they call them. your problems may go away. Mine did....
