-   -   Oil on spark-plugs and wires (https://hondaforum.com/forum/honda-accord-forum-11/oil-spark-plugs-wires-4659/)
gracewalters88 Oct 6, 2009 04:14 PM
I'm having troubles with my 93' Honda Accord LX. We recently changed the plugs and wires, to find they were coverd with oil.. So- we changed the upper seals, and gaskets..
But, is still leaking, causing mild mis-fires. Do we need to change the bottom seals?
At a Lost...
:rolleyes: Please reply suggestions!
matimar30 Oct 6, 2009 07:56 PM
i just had the same problem. yes the lower seals need to be replaced. i recommend factory replacement from honda. pay a little bit more and the the good stuff. while you're at it replace the spark plug wires, dist cap and rotor also. the oil damaged my plugs. got a bosch with a lifetime warrenty from autozone for 45.99 i have a 93 accord lx with F22a1 so if its them same as yours then it's model#09830 and i also put ngk iridium spark plugs xp5224. also check the ignition module(mine is within specks but i replaced it anyways) & coils. i live in san jose.
hope this helps
