-   -   Power window (https://hondaforum.com/forum/honda-accord-forum-11/power-window-12677/)
Dmil74 May 18, 2018 09:26 AM
Power window 96 accord
Rear passenger window 96 accord does not go down when operated by the master switch. It works fine at the door switch. It does go up from the master switch, but not down. Also, the front passenger window will only lower from master switch, will not raise back up. Switch on door works fine. These problems did not start at the same time. Bought used about a year ago with front passenger window problem. Back seat window problem just started a week ago. Thanks.
Dmil74 May 18, 2018 11:29 AM
Jiggled and applied a little pressure on master switch for back seat passenger side window. Started working. No change doing the same for front passenger side window with master switch. Any feedback much appreciated. Thanks
acmech52 May 19, 2018 01:23 PM
welcome to the forum. might try a good used master switch from a salvage yard, or ebay. seems the master contacts are weak or dirty
bucwheat May 19, 2018 07:41 PM
I agree,worn or dirty contacts,new switches should prove to be the answer.
