quick qustion and possible quick fix,
Hey guys, I've got a 97 LX with a 2.2 that I beleive is leaking from the dist. is there either a gasket or an "O" ring missing that could be causing this?:confused:
Welcome in,you most likely have a crack in in the cap,replace it.
welcome to the forum. View hondaautomotiveparts.com and put in your car info. there is an o ring at the base of the distributor item #6.
Thanks for the 411. Also where would the oil pressure sending unit be located?
above the oil filter
| All times are GMT -5. The time now is 07:12 AM. |
