Starter issue 2013 accord v6
Old 03-15-2021 | 01:42 PM
Kateshonda2013's Avatar
Default Starter issue 2013 accord v6
Looking for others who’ve had stated issues with their 2013 Honda Accord V6
Old 03-15-2021 | 09:51 PM
Must be missing some information.
Is your vehicle equipped with a push to start button?
If it is a key then why do you need to push the brakes?
When you try to start 5-6 times, does the engine crank or not?
And what is the service bulletin saying?
We are not there to see all the little thing which you take for granted.
Sorry, more questions and no answers
Old 06-23-2023 | 10:10 PM
DONOTPANIC's Avatar
Default Weird noise on start
Cam chain tensioner (#1 cause in 9th & 10th gen accords), atc or vtc actuator is the main issues surrounding that noise on start. Unless you've removed, replaced or bought aftermarket, then the heat shield around the upper catalytic converter isn't the cause. The heat shield under the car for the engine bay would sound like a piece of tin sheet metal, you'd only hear it when hitting bumps and such. Unless its clips are going then it would be louder, as if you drove over a traffic sign
USCDad72
11-22-2018 09:28 AM
forevermemorable
10-08-2013 09:57 PM
Abagumyan
06-02-2010 03:45 AM
jjmoodogg
04-02-2009 06:29 AM
ninjaflex
12-22-2008 12:35 PM
