Sponsored by:
Sponsored by:
Transmission
Old 07-15-2018, 01:07 AM
Marcos Saucedo's Avatar
Default Transmission
I have a 2002 accord coupe 2.3L W/Vtech. My transmission is automatic and hits 1st and 2nd gear pretty hard. The trans has 240xxx miles on it and I want to know if there is anything I can do that will make the trans run a lot better. I’ve also looked into just buying a new transmission for the car but i want to see what I can do. Should I just buy the same trans for my model or is there other options out there like different transmissions that can fit in my car. Looking for any help and any advice.
Old 07-15-2018, 05:34 PM
welcome to the forum: you've got some good miles on that trans. only thing i can suggest is to take it to a shop that works on hondas and uses only honda fluid and have them change the fluid, may take a couple of times, it may smooth out. if not you might consider replacing the trans of have it overhauled by a reputable shop.
Old 07-15-2018, 05:41 PM
thanks for the advice. I’ll probably do just that then.
Michelle Ellehcim
11-30-2018 07:26 PM
Twiztedchevy
05-30-2018 05:33 PM
rsstevens
07-04-2010 05:55 PM
tampa1
04-28-2010 02:13 AM
Razorbacksfan88
11-17-2006 10:53 PM
Quick Reply: Transmission
