-   -   Trouble Light Trouble (https://hondaforum.com/forum/honda-accord-forum-11/trouble-light-trouble-6316/)
captmoto Aug 29, 2010 10:15 PM
Hi everyone. I have a 2000 Accord with 2 lights staying on all the time. The traction control light on top in yellow and the (parking) brake light on at the bottom in red. I have new brakes pads and rotors all around, I have tried to clear all codes by using the odometer and don't see any codes with a code scanner. In the owners manual it says the brake light will stay on when brake fluid is low but fluid is OK. My next guess is maybe something off in the p brake system but what would that have to do with the TC indicator?
Thanks,
Steve
adam696 Sep 1, 2010 08:41 AM
I think there must be any wiring problem due to which its happening.Do check the wiring system.
acmech52 Sep 1, 2010 11:51 AM
captmoto welcome to the forum. check the filter in the brake resevoir it may be dirty. use a turkey basting tool to suck out some of the fluid and check for cleaness. if filter is clean, check your brake light switch on the pedal. or switch under the e-brake handle.
bucwheat Sep 3, 2010 10:52 AM
Acmech clued me in on that one last year and it worked for me,once the screen is cleaned and put back in the light went out.
captmoto Sep 4, 2010 10:45 AM
Thanks all, I looked at the screen but not real close. I'll clean it anyway and give it a shot. I dc'd the plug on the res and that shut them down. Other forums say that means the switch in the res is bad and need a new MC. The switch by itself is not replaceable. I'll check the other switches too.
Thanks
