-   -   Vibration when braking (https://hondaforum.com/forum/honda-accord-forum-11/vibration-when-braking-3301/)
ady5179 Jan 12, 2009 07:03 AM
My car Honda Accord 2.0 SM4 CB3 model 1991.WhenI brake mycar steering vibrate. I was change original brake pad, skin the brake disc (in range not over limit),change the brake piston kit,both tie rod,shock absorber,tyre, drive shaft external left.During tyre changing I do alignment, tyre balancing. Can anybody tell me?
acmech52 Jan 12, 2009 11:41 AM
RE: Vibration when braking
when you say skin the brake disk, I take it to say the disk/rotor was machined flat/ or trued, ( back to perfect new?) If the disk is true, the brake pad is new, jack up one side of your front wheels and have someone place in gear to rotate the tire and see if the rim or half shaft is warped or cv worn. besure to place chocksin front and back of all wheels on the ground incase the opposite wheel pulls a bit the car will not fall of the jacks.
