windows fogging up
Old Dec 28, 2008 | 12:20 PM
rbmount's Avatar
Default windows fogging up
I have a 97 Accord and I've noticed when i drive that my windows fog up. The problem is, i am not losing any coolant, the reserve tank is always full. I can roll a window down, and the fog goes away. When i park the car, there is no moisture inside the windshield, the carpet is dry, and there is no visible coolant under the car when I park it. Also, I don't see anabnormal or rapidloss in pressure on the hoses when the car is shut off when I get home in the evening.
Has anyone had this problem or a suggestion? Thanks in advance.
Old Jan 1, 2009 | 10:12 PM
Default RE: windows fogging up
welcome to the forum, is your a/c system working, the a/c system gives off dry air to clear the fogging up windows, if the a/c system is inop, you have humid air in the car and will not clear up until the window is down.
Old Jan 4, 2009 | 09:30 AM
rbmount's Avatar
Thanks for your reply, but I found the solution. I had the recurculating switch in recirc, instead of fresh air. I found the owners manual for the car and it says to run it in fresh air mode or the windows will fog up. I have never had this occur in my past vehicles. But I now know. Even my '09 Corolla does the same thing.
Old Jan 5, 2009 | 04:38 PM
thank you kindly for the fix, now we can all gain knowledge on a fogging window fix.
broshot
May 14, 2009 04:10 PM
kantersp
Apr 19, 2009 07:12 PM
arcedence
Sep 17, 2008 06:40 AM
Neyne
Mar 23, 2008 09:20 PM
99CivicEX
Aug 1, 2007 11:36 AM
