-   -   Wiper issue (https://hondaforum.com/forum/honda-accord-forum-11/wiper-issue-6417/)
cvanderhoef Sep 22, 2010 01:16 PM
Wiper issue
Hi all, the wiper on the driver's side won't stay down (touching the glass). I can push the wiper down so that it touches the glass but when I use the wipers the wiper comes off the glass. Any ideas on why this is happening and a fix? Thanks.
sean62 Sep 22, 2010 10:41 PM
I would suggest you to check the car's manual.there it would be given why such thing is happening.
acmech52 Sep 23, 2010 03:30 AM
have you checked to see if the nut holding the wiper blade down is loose.
cvanderhoef Sep 23, 2010 07:42 AM
I'll check the manual but I'm sure it won't be listed in there. I have checked nut and it was tight but I'll check that again to be sure.
cvanderhoef Sep 24, 2010 07:54 AM
Rechecked the nut and it is tight. Haven't checked the manual yet.
acmech52 Sep 25, 2010 03:35 AM
did you check to see if the spring tension on the wiper is good, sometimes it gets weak or breaks.
cvanderhoef Sep 26, 2010 07:12 AM
Nope didn't do that. What's the best way of testing the tension of the spring? Thanks.
bucwheat Oct 1, 2010 10:54 AM
Check the tension on the other side It should be the same ,if not try getting another arm.
