1986 crx si |
09-11-2023 11:57 PM |
1986 crx si fuel injected
Hi thank you for taking you’re time to read this as I am in dire need of help and I am stuck, my crx has been running a little sluggish and at first it was just a misfire so I changed the spark plugs, fixed the problem for a while until the pgmfi light comes on so I run injector cleaner and it fixed for a little, so then I think and I check the fuel filter and it was bad so I changed that as well as the fuel pump and the ignition coil as well as the distributor cap and rotor, none of these seemed to really help except I can tell my fuel pressure is better as it’s not misfire just sluggish now, could this be from a lack of air, well and quite frankly I don’t know what to do please help, thank you.
