1991 Civic with Code 1
Old Feb 6, 2009 | 10:10 AM
samahi72's Avatar
Default 1991 Civic with Code 1
1991 1.5 Sedan, Automatic.
What else beside an oxygen sensor could cause a code 1? I am told that my symptons do not indicate the oxygen sensor.
Here they are. In the morning, the check engine light is not on. Around 10 minutes into the drive, the motor will run rough for around 5 seconds, then the check engine light comes on and the car smooths out and runs fine for the rest of the journey. Next time I start it, the sequence starts all over again. I have also noticed that my fuel economy has gone way down.
So any help would be greatly appreciated.
Thanks
Old Feb 7, 2009 | 06:41 AM
spark plugs, wires, map sensor, throttle postion sensor, compression check. When was your last tune up?
Old Feb 9, 2009 | 11:07 AM
samahi72's Avatar
Hooray!!! I was getting ready to replace the oxygen sensor and found the wire broke. Maybe it got caught in the fan??? Anyway, I repaired the wire, reset the ECU and no more problem.
Old Feb 9, 2009 | 07:33 PM
great find, hope this is a good fix!
slayer08
Aug 19, 2009 11:06 AM
91haydenSI
Aug 3, 2009 03:20 PM
alewis36
Jul 21, 2009 08:23 PM
slayer08
Apr 29, 2009 03:59 AM
bebo85
Jul 11, 2007 01:31 PM
