1991 Civic Fuel System problems
Hello,
I have a 1991 Civic 1.5L. It is a manual transmission and I have been fixing it up. At this point I have replaced the distributor. The old one had bad bearings. With the new distributor I had to change the order of the plug wires because the distributor only fits one way and the rotor was 180 degrees flipped. Fuel injectors(it is a dual point with throttle body) and the Air Intake Temperature Sensor were also replaced. The ECU is throwing codes 10 and 16 even though I have replaced those parts. I cleaned all the groundstraps and wires to the engine and body. I checked the voltage to the AIT Sensor and it was working properly. Just wondering if anyone can point me in the right direction. Thanks for your help in advance. |
Also the timing is where it should be.
