2001 civic shakes at 40-50 HELP!
Hello i have a 2001 honda civic lx manual.
Recently worked on a few things, i changed both axels, right front wheel bearing, both control arm bushings, front left sway bar link, timing belt and water pump also have new tires balanced and alignment. The problem is that when i accelerate around 40 to 50 mph the car shakes (like a wobble) if i let go of the gas it stops if i press it shekes again it was not doing that before. A mechanic saod it could be the struts. Any help will be greatly appreciated thanks |
You did take it in for an alignment ,right? It sounds like possible a wheel bearing problem.
