2007 Civic Coupe EX STEERING issue, HELP
Hi.
Daughter has an Civic EX Coupe, automatic transmission that had the recalled original block replaced with newer model. Issue; This car has been aligned by two different Honda dealerships four times total. The last one got it right. However, the steering is so tight that the car is fatiguing to drive. If you move your hand just a hair either way, your going that way pronto! Now if it was a racecar, then we would be ok with that, but it's not. We do have a Chilton manual and I'm curious if there is an adjustment screw or whatever to loosen it up a little bit. Give it some play, so one can relax while driving it. Without having to go back to the dealership $$$. Thank you kindly! |
Your going to have to find a better forum!
