94 hatchback Eg with h22a1 swap looking for advice
I have recently acquired a 94 eg with an h22a1 blue top 5 speed swap in it. This is what I know about it.
H22a1 approximately 170k but rebuilt pulled from a 96 prelude Skunk 2 coilovers Bwr camber kit 15" Rota 5 spoke rims Chipped p28 Slim electric fan wired to dash. Spectre cold air intake Skunk 2 intake manifold 70mm Skunk 2 vavle springs skunk 2 cams and gears Clutch master stage 2 clutch 8lb flywheel tri-y header 3" pipe custom straight pipe. Skunk 2 shifter nob Innovative mounts map sensor (not sure the brand) battery relocated to trunk no power steering custom axles New alternator and belt Have A/c mount plate and condenser.(not installed) Car runs seemingly well and is pretty fast. have fog lights not installed Redlines at 6800 rpm Cons: Door locks don't work (no alarm either) Driver door doesn't align correct with (seems like 1/4 inch low) front seats are trash floor counsel with shift knob in it is not attached to the floor. Radio has power but doesn't work (not sure if speakers do either) no a/c no panel cover under steering wheel or fuse cover missing some trim around car Car smells like gas while on. Dent at bend in header because the guy I got it from slammed the car and has like 3 inch clearance to the ground.... car is lower then the pictures right now Biggest problems: Won't pass emissions Speedometer reads about 8-10 miles per hour faster then actual speed... looks like it has the D16 dash speedometers still in it. gas tank pressure builds up (when I open gas cap there is a pretty big wsshhhhhing noise from the air escaping). What I'd like to do pass emmisions fix gas tank pressure (not sure if its normal or not) Add a/c fix speedometer Fix Stereo system add fog lights get alarm Trying to make it more functional and reliable. If you have any suggestions or advice write me or post. Much Appreciated |
