98 civic ex wont start
Old Jun 26, 2007 | 01:28 AM
cyntherian's Avatar
Default 98 civic ex wont start
I was doing a compression test on the car and went to start it afterwards and it kept trying to crank over but wouldnt start.
All the ignition wires are attached in the right order on the d. cap and cylinders. I had all 4 spark plugs out at the same time when I was performing the compression test on one cylinder at a time. Any clues why my car wouldn't start afterwards?
Old Jun 26, 2007 | 02:02 AM
97_civic's Avatar
Default RE: 98 civic ex wont start
y were u doin the test in the first place?
Old Jun 26, 2007 | 03:10 AM
cyntherian's Avatar
My car was overheating so I was checking the compression in the cylinders for a leaky head gasket. I looked up the test in the Haynes manual just now and realized I didn't disable the fuel system by removing the PGM-FI main relay fuse.
All I did was unplug the ignition wires from the the spark plugs and removed all the plugs at the same time. I attached the tester to each cylinder and cranked the engine about ten times for each cylinder. I installed the plugs and the wires are in the right order but now the car wont start.
antonio97b
Feb 19, 2018 02:51 PM
splat41
Mar 16, 2010 12:19 AM
milholm
Feb 11, 2010 03:11 AM
splat41
Feb 10, 2010 11:33 PM
alewis36
Jul 21, 2009 08:23 PM
