B18C1 Into A 97 EX Coupe Before Swap
Hi guys,
I'm getting ready to swap a B18C1 GSR motor into my 97 Ex Coupe Civic.
It's a Full Conversion Motor, Trans, Axles, ECU, Mounts, Everything
Here's my questions?
I need a GSR Header now correct?
Do the 1.6 SOHC Wiring Plug into the B18C1 senors? The B18 will be OBD 2
And being this is a imported motor from Japan what should I check while the motor is out and easy to work on?
Should I look at the Clutch? Bearings? Crank? Timing Belts? (Should I replace the Oil Pump?)
I dont want to spend the time and money to put this motor into my car only to find that in a month it needs to be pulled due to a part inside the engine!
I think i'll replace the Knock sensor while it's out to be sure being that its a pain to get too!
Please give me any thoughts and if you have done this swap any things to watch out for or head aches you had!
Thanks Guys!
Thanks Guys!
Ravenous117
Mar 27, 2014 03:35 PM
webucher
Feb 13, 2006 06:28 PM
