Bizarre Flasher Problem
Hey all,
So I finally thought I would join, because after so many threads I've seen, on here and other forums, I could never discover the answer to the bizarre flasher issue I'm having on my turn signals. All wiring is correct, bulbs work, fuses replaced, etc. Long story short, my turn signals work just fine during the day. However, when I flip my lights on at night, obviously my turn signals stay illuminated. But, when I try to use either the left or right turn signal, it won't flash. It shows its flashing like usual in my car, just not the front turn signals. They just remain illuminated. And I've never found a single forum or an answer on every Google search you could imagine. Thus, why I'm here. Bought a new flasher relay. Solved hyper flashing. But not the signaling issue. It. Does not. Make. Sense. |
Originally Posted by technotrevor
(Post 26517)
Hey all,
welcome to the forum. Sorry for the slow response. Have you checked your emergency light switch. This sometimes goes bad and causes the turn signals act odd.
my switch went bad and i had no signal lights in my case. |
Originally Posted by acmech52
(Post 26537)
One thought was having the 12v and Intermittent crossed, but if that was true, wouldn't they not even flash when the Parking Lights are off? |
parking lights off, emergency flashers will flash if depressed. if 12v intermittent crossed would cause burning smell, and a few other items to short out.
(Post 26540)
I even have electronic relay as well. |
(Post 26542)
So then I'm definetly going to weigh out that hypothesis.
I even have electronic relay as well. How unfortunate lol. |
Bump.
Sorry,can't find anything on your problem ,but a simple thing to try is replacing the flasher.
