‘89 civic fails to crank
Hey guys,
I have a 89 civic DX. I have replaced the starter, alternator, and a new battery within the past month and a half. I am now having problems cranking the car. Sometimes it will fire right up and other times it will only make a clicking noise under the dash. The car will crank if you put cables on it but not with a jump box. Any thoughts on what’s wrong? Any help would be greatly appreciated. |
Ignition switch?
(Post 42123)
Ignition switch?
Originally Posted by 89dx
(Post 42125)
Thank you, that had crossed my mind. But why would it crank with jumper cables if it was the ignition switch?
(Post 42126)
Nothing. That tells me the cables are not attached correctly. Need to clean and tighten.
Is the battery fully charged?
(Post 42128)
yes, brand new batter (bought within 2 weeks) and a volt meter shows it’s fully charged. |
(Post 42129)
might also check all the ground wires/strap, take off the clean scrap and reinstall for good contact.
Originally Posted by acmech52
(Post 42150)
thank you both for your help. I have come to the conclusion it is a ground issue. I am working on cleaning the thermostat ground now because it was very dirty/corroded. This ground has to do with grounding the main relay if I’m not mistaken which is the clicking noise I’ve been hearing under my dash when trying to start the car. I’ll update when I have an update. Thank y’all again. |
| All times are GMT -5. The time now is 09:52 AM. |
