Civic Si, 1990; identity of parts on the engine.
Hi,
This photo illustrates the rear side of the engine in a Civic Si, 1990. The intake manifold has been removed and the red gasket remains on the head. The connection for the oil filter is in the lower left. http://easthope.ca/CivicSi1990EngineRear.jpg Will someone please explain two parts which I haven't yet found in the Haynes manual. (1) The steel tube, about 2 cm diameter, running across the block above the oil filter connection. (2) The object on the right side of the oil filter connection. Approximately square shaped with round corners and a rubber surface. Thanks, ... Peter E. |
(1) The steel tube, about 2 cm diameter, running across the block above the oil filter connection. components - exploded view" the steel tube is part "7 Water pump inlet pipe". (2) The object on the right side of the oil filter connection. Approximately square shaped with round corners and a rubber surface. Regards, ... Peter E. |
