D16 wont start sometimes
I have a D16 in my CRX and sometimes it doesn't want to start. It cranks but it won't turn over. (For example)You can try to start it 10 times and it might start up on the 11th crank. Its a random deal but still annoying. So far it will start after messing with it but in the future it might not start at all. Anyone know what the problem could be?
RE: D16 wont start sometimes
providing your spark plugs and wires are good, check your fuel path, and distributor coil.
d16's have a problem with their fuel pump relay i would advise that you replace the relay for a cheap and probable fix. other wise if it stumbles when it actually starts check your fuel pressure regulator and fuel filter. any could be causeing the problem
