Honda Civic CRX Si Engine Help
Old 05-14-2018, 08:00 PM
Hunter Schotts's Avatar
Default Honda Civic CRX Si Engine Help
Hey guys, I’m new here but I own a 1990 Honda CRX Si and am having engine problems. I started it up about 3 weeks ago and the check engine light came on and the idol was completely off. It was a low hum and the car was vibrating real bad. I shut the car off and fast forward 2 weeks, the car isn’t starting. I was advised to put new plugs in and i did - same problem. So today i pumped the pedal a few times and it started! Same problems as before but then i thought fuel injectors? Any advice / thoughts welcomed.
Thanks!
Old 05-15-2018, 01:29 PM
2thpic's Avatar
Member
Have you checked the fuel pump and or fuel pressure.
Not on a Honda but on a diff. car I was working on it had sim. issue and it was the fuel pressure regulator.
I picked mine up from a junk yard of a car that was wrecked, so I know it was running b4.
It's a cheaper way to find out what part is wrong and then if so wanted go get a new one with warranty.
Ricers 4 life
05-14-2013 08:18 AM
84crx
08-13-2009 01:42 PM
nathancrowder
10-23-2008 12:28 AM
hondatuner14
12-28-2006 01:20 AM
crxkid
08-03-2006 06:35 PM
Quick Reply: Honda Civic CRX Si Engine Help
