Dash Brake Light
Car: 2000 Honda Civic DX
I recently had the brakes overhauled on this car at a local shop. Everything was replaced except for the springs and hardware for the rear drum brakes. After about a month, the red brake light on the dash has come on...but not all the way...it's dim...and at times gets a little brighter then dims back down. I've make sure all my outside brake lights work. I've not noticed any change in braking at all. Any ideas? |
RE: Dash Brake Light
welcome to the forum tattoo432: enjoy your stay. Check your master cylinger for proper fluid level. Also check to see if all the brake lights are working properly.
check if the relay is in good shape if not u could buy it at autozone or a junk yard. u chould also check the spring and hardware for the drums thats a big deal when it comes to brake because your e-brake my not work properly later on
i got the similar problem with you and i have fixed it now.
the problem is brake switch. please check it out...maybe your problem the same with me. hope this help. |
| All times are GMT -5. The time now is 06:51 AM. |
