door panel
how do i get these god damn things off
RE: door panel
their are few screws. should be one by the inner handle with a cap over it. one by the ejector handle, umm one plastic one in the front by your speaker on top and that about it u should be able to pull it out if you pop out the plastic plugs behind the cover..
RE: door panel
depending on whether it is auto or manual windows/doors, you should have one in the handle, one by the speaker(or up top by the mirror), and if you have manual windows then you will have to get a flathead screwdriver and pry off the handle far enough to release a clip that holds it on (very tightly i might add), then after that it should just be a matter of the headache of wiggling the thing loose and over the door locks. Good luck man. Just play with it. Civics are pretty easy to take apart.
