Driver Door sticky and intermittently wont open
I have an '08 Civic LX Manual, and I have just started having my door not letting me out when I try to leave through the driver door. It only happens about once a week, and when it does I can usually hit the door panel and it will then let me open. Also, the outside handle of the same door is sticky and doesnt spring back to its original place like it used to, but just hangs a little ways off like a springs has gone bad or something.
I have taken the panel off and poked around, and will replace parts if needed but wondered if I can get specific guidance before replacing parts I need to. Thanks! |
First try white lithium spray on moving parts and the latch,if no help try operating the handle with the panel off to see if something is catching. I have seen loose components at times that a little tightening can help. |
