Firewall
I am trying to install an amp in 2007 Honda Civic. I know that on the automatics you can go thru the firewall where the clutch pedal would be. However, this Civic is a manual and obviously has a clutch, so that will not work. I was wondering if anyone knew another place to go thru the fire wall with a 4 gauge power wire.
RE: Firewall
well. if you check under your dash follow your harness to an opening. or you can check where your A/C gaps and fittings to see if you can get clearence for a a 4 gauge.
