Help identifying the part
Old Jul 9, 2024 | 12:10 PM
Tracker's Avatar
Default Help identifying the part
Hi. Can you please tell what this part called? I can't find it anywhere on honda parts web sites or ebay. All I see are the vertical middle pillars, or the long horizontal trim. But not this upper piece that curves around. It's a 2009 Civic.
Old Jul 10, 2024 | 08:58 PM
welcome to the forum. may be called the door shell. its all one piece. or door panel
Old Jul 10, 2024 | 09:03 PM
Tracker's Avatar
Thanks! So that piece is not removable? Not like those middle pillars? If so the only way to make it look better is to repaint it. Cause I don't even see anyone selling any stripes that would go over the part with adhesive..
Old Jul 11, 2024 | 09:05 AM
Operation CHARM: Car repair manuals for everyone.
Home >> Honda >> 2009 >> Civic L4-1.8L >> Repair and Diagnosis >> Body and Frame >> Weatherstrip >> Front Door Window Glass Weatherstrip >> Service and Repair >> Front Door Glass Outer Weatherstrip Replacement (4-Door)
4-door
NOTE:
- Put on gloves to protect your hands.
- Take care not to scratch the door.
1. Lower the glass fully.
2. Release the front hook (A) from inside of the door, then pull up the front door glass outer weatherstrip (B).
3. Starting at the front, slowly pull up the front door glass outer weatherstrip (A).
4. Slide the front door glass outer weatherstrip (A) forward.
5. Twist the front door glass outer weatherstrip (A) to pull the rear hook (B) out from the inside of the door, then remove the weatherstrip.
6. Push the clip portions of new front door glass outer weatherstrip into place securely.
pro multis · About Operation CHARM
Home >> Honda >> 2009 >> Civic L4-1.8L >> Repair and Diagnosis >> Body and Frame >> Weatherstrip >> Front Door Weatherstrip >> Service and Repair
Front Door Weatherstrip: Service and Repair
Front Door Weatherstrip Replacement
NOTE:
- Use a clip remover to remove the clips.
1. At the A-pillar, remove the door checker mounting bolt (A).
2. Detach the clips (B, C, D, E), then remove the door weatherstrip (F).
3. Install the weatherstrip in the reverse order of removal, and note these items:
- If the clips are damaged or stress-whitened, replace them with new ones.
- Make sure the weatherstrip is installed in the holder (G) securely.
- Apply medium strength liquid thread lock to door checker mounting bolt before installation.
- When reinstalling the door panel, make sure the plastic cover is installed properly and sealed around its outside perimeter to seal out water.
- Check for water leaks. Adjustments
2-door
4-door
Grg310
Feb 7, 2022 09:15 PM
Plumberdude3
Feb 4, 2022 03:21 PM
Sep 30, 2009 12:17 PM
torres
Mar 25, 2008 04:14 PM
