High idle and off idle "dead" spot
Old Nov 11, 2011 | 07:03 PM
bcole6's Avatar
Default High idle and off idle "dead" spot
I have a 97 civic with the D16Y8 motor. Motor idles high, 1500-1700 most of the time, especially after warming up. It also has a slight "dead" spot just off idle at around 2000 RPM, which also seems to get worse at random, but is always there to some degree. When its bad, it is hard to drive (5 speed) around town when you only have to be on the throttle a little bit. If you go up thru the gears accelerating hard, it's perfect, very smooth. I changed IAC yesterday, no change. No check engine light. According to a Haynes manual I purchased, this motor does not have EGR, FIT or IAB valve. What else should I be looking for?
Old Nov 21, 2011 | 10:03 PM
Derek_Miller's Avatar
You should recheck the voltage of the battery connected and just clean out whatever valve the motor comes with. I am not too knowledgable about 97 civic motor but this is a common problem in many cars. Hope i helped.
Old Nov 26, 2011 | 02:53 AM
VTECKICKER's Avatar
its your motor begging for vtec!
Old Nov 28, 2011 | 10:32 AM
Old Apr 30, 2013 | 09:30 AM
crucialtrini's Avatar
It is you iac valve most likely, clean it or change throttle body
oops didn't read everything
notastupidname
Jan 12, 2013 05:52 PM
r0b369
Jan 24, 2012 07:48 AM
RyanFormula
Jul 5, 2010 09:48 AM
splat41
May 26, 2008 11:11 PM
mattsthru
May 27, 2007 07:15 PM
