Honda Civic CRX Si Engine Help
Hey guys, I’m new here but I own a 1990 Honda CRX Si and am having engine problems. I started it up about 3 weeks ago and the check engine light came on and the idol was completely off. It was a low hum and the car was vibrating real bad. I shut the car off and fast forward 2 weeks, the car isn’t starting. I was advised to put new plugs in and i did - same problem. So today i pumped the pedal a few times and it started! Same problems as before but then i thought fuel injectors? Any advice / thoughts welcomed. Thanks! |
Have you checked the fuel pump and or fuel pressure.
Not on a Honda but on a diff. car I was working on it had sim. issue and it was the fuel pressure regulator. I picked mine up from a junk yard of a car that was wrecked, so I know it was running b4. It's a cheaper way to find out what part is wrong and then if so wanted go get a new one with warranty. |
