Honda Civic CX 97 1.6L - Diagnostic Code help
P0141 - O2 Sensor Heater Circuit Bank 1 Sensor 2
P0700 - Transmission Control System (MIL Request) P0715 - Input Turbine Speed Sensor "A" Circuit P0301 - Cylinder 1 Misfire Detected P0302 - Cylinder 2 Misfire Detected P0303 - Cylinder 3 Misfire Detected P1300 - Unknown Diagnostic Trouble Code Hi guys, So far spark plugs have been replaced, catalytic converter, and distributor. We need some help on the following codes. P0141 - Is that the second sensor under the car? P0700 - Anyone have any known fixes? or is this just from the misfires? P0715 - Any other possible issues besides replacing the Speed Sensor? P0301 - Clicking and gave 13.0 Ohm reading P0302 - Clicking and gave 12.8 Ohm reading P0303 - Clicking and gave 12.8 Ohm reading Also, Cylinder 4 gave a 13.0 Ohm reading, if I'm reading this the correct way... starting from the injector nearest to driver side then across. P1300 - Not sure what this is. Car drove fine before the spark plug change, it now overheats. No transmission slips. Speedometer is not working. Any help would be great! Thanks! |
