How to replace turn signal bulb in a '98?!!!
Old Feb 25, 2009 | 12:39 PM
broguearcher's Avatar
Default How to replace turn signal bulb in a '98?!!!
It appears that the right front turn signal bulb needs to be replaced in my '98 Civic DX. How do I go about removing the headlight housing in order to access the bulb?
thanks!
Sam
Old Mar 6, 2009 | 02:37 AM
brittanyultra's Avatar
Autozone can figure it out but you probly have to take some things out..
which side is it on?
Old Mar 6, 2009 | 03:06 AM
remove the clips on the wheel well guard ( plastic to prevent water from splashing into the light area,) stick your arm into the back of the light and remove and replace the turn signal bulb. If you turn your wheel to the left, there will be more room to get the splash guard open to get your arm in. If you go to hondaautomotiveparts.com and look at the diagram, it may assist you better.
Old Mar 6, 2009 | 08:19 PM
thanks. I'll try this out tomorrow!
Sam
crvfan837
Aug 17, 2010 04:01 AM
vilfredo
Mar 7, 2009 11:00 AM
broguearcher
Feb 25, 2009 10:34 PM
mechaincal_nut
Mar 13, 2008 03:25 AM
Eric17
Apr 19, 2006 09:48 PM
