Lost spark n gas at once
I have a 97 Civic DX coupe, it was running perfectly. I was going down the road and it shut off and wouldn't start. I lost power to the fuel pump but tested the pump and its fine i lost spark and my main relay quit clicking on ignition. I checked EVERY fuse and replaced the main relay but still in the same situation. I have power to EVERYTHING else but whats mentioned above. Any input would be greatly appreciated
RE: Lost spark n gas at once
Did you use a spark tester? Did you check for a noid (are your injectors getting power)? Either your distributor died or you have bad crank or cam sensor depending on the set up.
how many miles you got on the 97, and when was the last time the timing belt was changed or checked?
