low beams help
Old Sep 3, 2009 | 06:23 PM
joel03civic's Avatar
Default low beams help
i was driving last night and switched on my hi beans, and when i turned low beams back on they stopped working. only the hi beams and parking lights and tail lights work but no low beams. i checked fuses and relay and they are ok. any suggestions would be great. thanks.
the car is a 2003 honda civic ex
Old Sep 4, 2009 | 01:00 PM
welcome to the forum. My son's 02 civic did the same thing, he went to high beam and then to low, and no lights, found both low beams on our case to be burnt out. Replace both bulbs and got good low beams. Also check for good ground and good contact. Our ground and contact were good and clean. bulbs in our case burnt out.
Old Sep 4, 2009 | 06:04 PM
thanks for input. its a strange coincidence that both bulbs would blow at the same exact time but its the only thing that makes sence. i'll give it a try hopefully thats all that wrong. thanks again.
Old Sep 5, 2009 | 01:38 PM
i changed the bulbs, that wasn't the problem also ground is good. what else should i check? is it possible the light switch went? i'm running out of ideas and i really don't want to bring the car to the shop. please help
Old Sep 5, 2009 | 05:44 PM
yes the light switch may be bad.
Walt L
Oct 2, 2013 10:47 PM
RyanWright32
Feb 1, 2012 11:04 AM
poscivic05
Jan 13, 2012 08:16 AM
benjammin
Sep 1, 2009 07:09 AM
jaywalt
Feb 5, 2009 10:18 PM
