Need Help with 2001 Maintenance
I have a 2001 Honda Civic with 154,000 miles. I brought a brand new engine from honda less than 2 years ago and replace the transmission with a used one about a year ago that had approx 40,000 miles on it.
My question is: I am unsure about the maintenance that I need to do. Since I have replaced the engine and transmission, what are the other major parts that I should have checked out to ensure that my civic last. Like any fluids flushed? Or belts replaced? I have also recently replaced... The front struts Lower control arm bushing Front/Rear brakes & Tires We asked honda to do a full diagnostic on the car and they said it would be $150. Even though that would applied to any work done, it would keep me bound to getting the work done there. I dont mind paying for the work but I dont want to be ripped off. Any suggestions? Thanks! |
welcome to the forum. Suggest you get a factory service manul. ebay does sell them. most of the work you can handle yourself. Transmission drain and flush each 3 years or 30k miles using honda trans fluid only. if driven a lot, once a year will not hurt. clean out your idle cut off vlv, throttle vave control. flush radiator each 2 years. cabin filter ea 30k miles. if you go to the honda site, it does have a schedule maintenance you can follow. Also the owners manual has a schedule maintenance sheet.
Annual checks are: antifreeze, brakes, distribution nelt, dampers lambda, probe filters and motor oil (they are replaced every year or 20,000 km). Do not have to replace them but must be checked
whats a probe filter sounds sexy.
:) i mean oil, air, AC, fuel filters
Hi !
If you diden't change the coolant every 3-4 years, it would a good ideea to change the radiator to. Some times, due to poor coolant quality and iregular changing intervals some elements of the radiator can be filled with a thik smuge. Hope this info helps. |
