no heat/blowing cold air
Old Jan 3, 2011 | 08:49 AM
dredreson's Avatar
Default no heat/blowing cold air
i just had a brand new heater core put into my civic, and its still blowing out cold air. any idea what could be wrong?
Old Jan 5, 2011 | 07:50 AM
Sounds like maybe a thermostat problem,when you put the core in did you make sure the coolant is leveled off? I'm assuming you checked and make sure everything is connected properly.The thermostat is not hard to replace and not expensive,just make sure not to overtighten the bolts on the housing and place the thermostat right side up.Good luck. Oh and don't forget to open the bleed screw on the housing.
CrossCountryDriver
Aug 29, 2014 10:35 PM
kschjei
May 6, 2014 04:32 PM
gonzo6580
Nov 19, 2009 09:40 PM
shad9876
Sep 3, 2008 12:57 PM
Allnbrgdn
Jul 17, 2006 11:09 PM
