Signal Problem
Old Nov 2, 2009 | 08:22 PM
jfred6's Avatar
Question Signal Problem
Hey everyone. I have a 97 Honda Civic and have a signal problem that started recently. The right signal either blinks too fast or too slow - the left is fine and when I put the hazard lights on they blink together. Both front and rear bulbs are not dim or out. I'm guessing it could be a wiring problem but I don't know where to begin. I like to save money by working on my car myself but I'm not near the expert level! Any suggestions are greatly appreciated. Thanks!
Old Nov 3, 2009 | 01:55 AM
welcome to the forum. First check to see that both front and back light bulbs have good ground and contact. ( a bulb may be going bad and not be noticable )
Old Nov 3, 2009 | 05:08 AM
jfred6's Avatar
Thanks for the reply. How do I make sure it has a good ground? Take it out and put it back in?
Old Nov 4, 2009 | 03:39 AM
take it out and use scotch bright to scrap it a bit, check the socket for cleaness. Look at the bulb and make sure it is not getting dark in color. check the wires to see if it goes to ground and clean that contact area. You may want to purchase a couple bulbs for troubleshooting purpose, or just replace the bulb with new ones. If this does not help, then there may be a wire problem.
Old Nov 12, 2009 | 06:21 AM
jfred6's Avatar
I just saw your reply. I'll try that. Thanks a lot!!!
Old Dec 7, 2009 | 07:53 AM
Domaeromi's Avatar
Default Signal Problem
anyone know the best place to tap into for an rsx tach signal? friend is trying to install aftermarket tach..thanks
Old Dec 23, 2009 | 04:15 AM
enzyday09's Avatar
OP do you have any aftermarket electrical mods? it sounds like the problem could be a short to power in the circuit. long story short, take it to the dealer and have them check it out. electrical diy maintenance sucks
tsmitherz21
Jan 17, 2011 01:05 PM
mechaincal_nut
Mar 13, 2008 03:25 AM
Mills
Aug 28, 2007 07:57 PM
ed1le
Jul 17, 2006 02:00 PM
Eric17
Apr 19, 2006 09:48 PM
