spedometer jumps then check engine light comes on
Old Apr 1, 2009 | 07:32 PM
WonderBoy3211's Avatar
Default spedometer jumps then check engine light comes on
I put a new motor (1.5 L) in my 95 civic dx a couple months ago. the car was running fine other than loping a little bit when it idles (still does it. anyone know how to fix that?) but when i drive it for about 30-40 minutes, my spedometer starts to jump and then drops and the check engine light comes on. anyone have any ideas? thanks....
Old Apr 1, 2009 | 09:32 PM
shogee's Avatar
you should check the connector plug to your vehicle speed sensor... look for corrosion or a loose connection... the vss is usually located on the rear side of your engine bay on the tranny, close to where the axles go into the tranny. if all that looks good you could replace the sensor... i suggest a new one, not one from a junk yard
Old Apr 8, 2009 | 05:24 PM
ricersforlife's Avatar
Your problem is you don't have enough horsepower you need to add more stickers and a three layer wing that should get you where you need to be.
KrisP
Aug 19, 2014 06:15 PM
rad384
Aug 17, 2012 10:32 PM
jhsu
Jul 2, 2010 02:56 PM
jordtee
Sep 18, 2008 04:57 AM
BigDan
Jul 25, 2006 12:22 AM
