Strange Fuel Problem
Old Dec 20, 2007 | 07:19 PM
fudwamper's Avatar
Default Strange Fuel Problem
I have a 1990 crx si and after 4-5 gallons the car acts like it ran out of gas. I just replaced the fuel pump and it is still acting the same way. Any suggestions or ideas of what is causing this?
Old Dec 21, 2007 | 02:52 AM
Default RE: Strange Fuel Problem
Welcome to the forum, Fuel Filter?
Old Dec 22, 2007 | 07:11 PM
fudwamper's Avatar
New filter same problem. 4-5 gallons then it sputters out like it is running out of gas. Any inexpensive way to check for an air leak?
Old Dec 23, 2007 | 08:40 AM
you can use starter fluid, if idle goes up, possible leak in that area, be careful not to apply to exhaust pipes or hot areas.
Old Dec 27, 2007 | 11:43 AM
NANDO's Avatar
I got same problem. i replaced the fuel pump twice and the sending unit. i going to put the old pump back in to see what happen's. 200 miles on a tank of gas suck's on acivic.
Old Dec 28, 2007 | 02:45 AM
check to see if your fuel tank has been cavitated, have seen this in an old model car, fuel sucked the tank in and shrunk it. Tank dropped from a 15gal to 10 gal capacity.
Old Jan 1, 2008 | 08:15 PM
NANDO's Avatar
My gas tank is good. do you need to put the old filter on the new pump? i noticed thattheold onewas longer and thinner then the new one, the new was short and rounder.
Old Jan 1, 2008 | 09:51 PM
keep new filter on the new pump. size is ok, if the filter was not good, it would show up right away, I will have to do more research to find out why after a short amount of miles the engine dies out, I will email you to a person who might be able to assist you, I will get into contact with him now.
Old Jan 1, 2008 | 10:04 PM
Sent email to friend, will get back to you when he answers. I am now guessing, would the gas cap be creating a vaccum strong enough to stop the fuel from pumping out, The next time the car stops, release the gas cap slowly and see if there might be a excessive amount of vaccum.
Old Jan 2, 2008 | 08:55 PM
  #10
NANDO's Avatar
Thank's for asking your friend. My car has stopped twice on the road, and it seem's like the car run's out of gas. i have bought 2 fuel pump's, a sending unit, gas cap, and a fuel pump relay. i went to autozone to buy a new stainer for the fuel pump. this stainer look's like the old stainer, but new. the strainer that is on the pump now is hafe the size of the one i bought from autozone.
